Gyeon Q2 CanCoat EVO bottle and box in front of a green BMW M3
Gyeon Q2 CanCoat EVO: Ceramic Protection in an Afternoon
A full ceramic coating is a weekend project at minimum. The paint has to be corrected, wiped down, coated panel by panel, and left inside overnight. It is worth it, and it is the protection work we are known for, but there are a lot of cars and a lot of owners for whom that is more than the situation calls for. A daily driver that gets washed every couple of weeks. A lease. A second car. An owner who wants the car to bead and stay clean and does not want to give up a weekend.
Gyeon Q2 CanCoat EVO is the product I point those owners to. It is a true SiO2 based ceramic coating in a spray bottle, applied with a towel in about the time it takes to apply a spray wax. Gyeon rates it at up to 12 months.
This post explains what CanCoat EVO is, how it differs from a full coating like Mohs EVO, how to prep and apply it, and how to keep it working for the year.
What Gyeon Q2 CanCoat EVO is
CanCoat EVO is a 200 ml bottle of SiO2 ceramic coating designed to be sprayed onto the included microfiber towel and wiped into the surface. Gyeon built it to be the fastest way to put a real ceramic layer on a car. The box comes with the bottle, three spray heads, and one microfiber towel.
Gyeon lists consumption at 10 to 15 ml per car, so one bottle covers a car many times over. The coating tolerates pH 2 to 11, the same range as Gyeon's full coatings, so normal wash chemicals will not strip it. Durability is rated at up to 12 months or 12,000 km, and Gyeon describes it as a yearly coating. That is the right way to think about it. Apply it once in spring, and again the following spring.
It goes on almost every exterior surface. Paint, plastic trim, headlamps, paint protection film, wheels, exhaust tips, and glass are all on Gyeon's list. That versatility is a big part of the appeal. One bottle and one towel handle the whole outside of the car.
Gyeon is specific about how it is meant to be applied. It is designed to be wiped in quickly and have the excess removed immediately. It is not designed for heavy cross hatched, overlapping passes. Treat it like a spray wax with a ceramic result and it behaves.
Gray BMW M3 covered in foam during a wash inside the Detailer's Domain shop
Spray ceramic coating vs a full ceramic coating
This is the question behind most of the emails I get about CanCoat, so here is the honest answer.
A full coating like Gyeon Q2 Mohs EVO is a thicker layer of a harder chemistry, a fluorine modified polysilazane. Gyeon rates one layer at up to 36 months and two layers at up to 48. It gives the highest gloss, the strongest chemical resistance, and the best long term slickness. It also demands the most from the surface under it. The paint should be corrected first, because the coating locks in whatever it covers, and the panels have to be chemically clean. For a careful owner that is a weekend.
A spray ceramic like CanCoat EVO is a thinner SiO2 layer rated for a year. It gives real water beading, real gloss, and real protection from UV and chemical exposure, and Gyeon states plainly that it outperforms any wax or sealant. It does not last three years or build the same depth. It still needs clean paint, but the prep is a wash, a decontamination, and a wipe down.
The way I explain it is this. Mohs EVO is for the car you want to protect for the long term and are willing to prep properly. CanCoat EVO is for the car you want protected this weekend. Both are real ceramic coatings.
There is one more use people overlook. CanCoat EVO goes over an existing coating. If your car has a full coating that is a couple of years in and the water behavior is fading, a layer of CanCoat EVO brings the beading back for the season without redoing the base coating.
Compare the two side by side
Tap either bottle to see what it asks of you and what it gives back.
Best forThe daily driver, the lease, the second car, and topping up an older coating.
Prep Wash, clay, and a panel wipe with Nanolex EX. Polishing is optional.
Application Two or three sprays on the towel, wipe in, wipe off immediately with a dry towel.
Rated durability Up to 12 months or 12,000 km.
Per car 10 to 15 ml, so the 200 ml bottle covers many applications.
Surfaces Paint, trim, headlamps, PPF, wheels, exhaust tips, and glass.
Price $62.99 for 200 ml, towel and spare spray heads included.
Add CanCoat EVO to cart
Gyeon Q2 Mohs EVO ceramic coating kit
Best forThe car you plan to keep, with paint worth correcting before it is locked in.
Prep Wash, clay, paint correction, and a thorough panel wipe. The coating preserves whatever is under it.
Application One layer with the included applicator, wiped off right away, then time for the coating to cure.
Rated durability Up to 36 months for one layer, up to 48 months for two.
Per car 15 to 25 ml. The 50 ml bottle leaves enough for the wheels.
Surfaces Paint, with the leftover going on wheels.
Price $64.99 for 30 ml, $89.99 for 50 ml.
See Mohs EVO
How to prep a car for CanCoat EVO
A spray coating still bonds to the paint, so the paint has to be clean. This is the part that separates a coating that lasts a year from one that fades by fall.
Start with a proper wash. Two buckets, pH neutral shampoo, top down, and a full rinse. Then decontaminate. Run your hand over the paint in a plastic bag after the wash. If it feels gritty, bonded contamination is sitting on the clear coat, and the coating will bond to the contamination, then let go when the contamination does. The Detailer's Domain Clay Sponge with plenty of lubricant removes overspray, sap, and rail dust, rinses clean, and can be used many times. Work on cool paint out of direct sun and keep it wet.
Dry the car completely. An Autofiber Dreadnought laid flat and pulled will do the whole car. Any water left in a seam will run out onto a panel you just coated.
Then wipe every panel with Nanolex EX. This strips the oils, old wax, and polish residue that would otherwise sit between the coating and the paint. It is the step people skip, and it is the step that decides whether you get a year.
How to apply CanCoat EVO
Work inside or in the shade on a cool panel. Fold the included microfiber into quarters and put two or three sprays on it. Wipe the product into a section, roughly half a hood at a time, in straight overlapping strokes. Then flip to a clean, dry microfiber and wipe the excess off immediately. Do not let it sit and flash.
Move around the car one section at a time and check each one from a low angle under good light before moving on. If you see a streak, buff it again with the dry towel right away. A high spot caught in the first minute wipes off. A high spot found the next day needs a fresh application of CanCoat to reactivate it, then a wipe.
Do the trim, the headlamps, the wheels, and the glass with the same towel and the same motion. Give the car a few hours before it sees water and keep it out of rain overnight. Skip the first wash for a week if you can.
Looking after it through the year
A CanCoat EVO car washes easily. Rinse first, foam, then a light two bucket wash. Most of the road film comes off before the mitt touches the car. Dry it fully every time. Water spots are the enemy of every coating, and a thin coating has less to give.
The coating is rated for up to 12 months, and around here the year is really about winter. Salt and brine sitting on the car for weeks at a time will shorten the life of any coating. I wrote about the winter routine in driving a coated car through a New Jersey winter, and the same rules apply to a spray coating. Rinse the car when the temperature allows, wash properly when you can, and do not let salt dry on the paint for a month.
When the beading starts to slow down, the car is telling you it is time. Wash, decontaminate if needed, wipe with EX, and reapply. That afternoon is the entire maintenance schedule.
Gyeon CanCoat EVO questions we get asked
How long does Gyeon CanCoat EVO last?
Gyeon rates it at up to 12 months or 12,000 km. A garaged car that is washed properly has the best chance at the full year. A car that lives outside through a New Jersey winter should plan on reapplying in spring.
Is CanCoat EVO a real ceramic coating?
Yes. It is an SiO2 based ceramic coating. It is thinner and shorter lived than a bottle coating like Mohs EVO, and it outperforms waxes and sealants.
Can I apply CanCoat EVO over paint protection film?
Yes. Paint protection film is on Gyeon's list of surfaces for CanCoat EVO.
Can I put CanCoat EVO on top of an existing ceramic coating?
Yes. It is a good way to refresh the water behavior on an older coating for another season.
How much CanCoat EVO do I need per car?
Gyeon lists consumption at 10 to 15 ml per car. The 200 ml bottle covers many applications.
Do I need to polish before applying CanCoat EVO?
Polishing is optional. Correction makes any coating look better, but CanCoat EVO only requires a clean, decontaminated, wiped down surface.
Can I apply CanCoat EVO in the sun?
Work on a cool panel in the shade or inside. Heat makes the product flash before you can wipe the excess off.
An afternoon well spent
Most cars will never get a full paint correction and a three year coating, and they do not need one. They need to be clean, protected, and easy to wash, and CanCoat EVO gets them there in an afternoon with a wash, a clay sponge, a wipe with EX, and a towel. It works, and it asks very little of you.
Gyeon Q2 CanCoat EVO 200 ml
Ceramic in an afternoon
Gyeon Q2 CanCoat EVO Ceramic Coating Spray, 200 ml
$62.99 · SiO2 spray coating rated up to 12 months, for paint, trim, glass, wheels, and PPF · towel and three spray heads in the box · ships from Norwood, NJ
Add to cart
Also in this post: Clay Sponge, $11.99 · Nanolex EX, $24.99 · Gyeon Q2 Mohs EVO, from $64.99
Phil
Previous article Rinseless Wash in Winter: Washing a Car With No Hose
Next article Koch Chemie Compounds: Which Cut for Which Job
