Glass Sealant Before Winter: Seeing Through Sleet at Night
The drive that convinces people is always the same one. Route 17 or the Parkway, around six in the evening, temperature hovering right at freezing, and the road is wet with something between rain and snow. Every truck ahead of you throws a gray mist of salt water onto the windshield. The wipers smear it, the oncoming headlights light the smear up, and for a second you are steering by memory.
On sealed glass that same spray beads and slides, the wipers clear it in one pass, and the headlight glare has much less to catch on. On bare glass you get the film, the smear, and the glare on every pass.
This post covers what a glass sealant does in cold weather, how to apply one so it lasts, and which of the two we stock makes sense for you.
What a windshield sealant does, and why it matters more in winter
A glass sealant is a coating that bonds to the surface of the glass and makes it repel water. On a summer afternoon that means rain beads up and rolls off. In winter it does more than that, because the stuff hitting your windshield is worse than rain. Salt brine, road grime, wet snow, the sludge that flies off the car ahead of you. All of it wants to stick to bare glass, and once it sticks the wipers just push it around.
Nanolex Ultra Glass Sealant is a nanotechnology coating built around SiO2, and it forms a barrier on the glass against water, oil and grime. Nanolex rates it for at least 18 months or 30,000 km, which covers this winter and next. Above roughly 25 mph the airflow carries the drops off the glass on its own, so on the highway you use the wipers far less. Around town you still use them, and the glass clears with one sweep because there is little for the water to grip.
Two winter benefits get less attention. Grime and bug splatter wash off easily, so the salt haze on a February morning takes less washer fluid to clear. And Nanolex notes that de-icing is much easier on treated glass. Frost still forms, and it lets go of the surface sooner when you scrape.
Does glass sealant work in winter?
Yes, and winter is when it earns its money. The question usually comes from people who tried a cheap rain repellent and watched it fade by Thanksgiving. The difference is in how the product bonds.
Nanolex Ultra Glass Sealant bonds to the glass and cures there. Once it is fully cured, which takes about 12 hours at normal room temperature, wiper blades, washer fluid and scrapers are working against a bonded layer.
The part people get wrong is the application temperature, and that matters in late November. The solvents have to flash off before you polish the residue away, and Nanolex specifies about two minutes at 20 degrees C. In a cold garage that takes longer, and if you rush it you smear product that has not set. Do it in a heated garage or on a mild afternoon, and give the car a night indoors to cure if you can. The other half of the answer is that the sealant is only as good as the glass under it, which is where most home applications fall short.
Nanolex Ultra Glass Sealant or nextzett Glass Sealant
We keep both on the shelf, and they suit different people. Pick one to see how it compares.
Best forNanolex Ultra Glass SealantYou want the glass done once, properly, and left alone until well into next year.
| Rated for | At least 18 months or 30,000 km. |
| Bottle | 30 ml. A windshield takes 3 to 6 ml, and about 15 ml does all the glass on a car. |
| Prep | Demanding. Glass cleaner, then polish or strip the glass until it is completely clean. |
| Apply | 10 to 15 drops on a cotton pad, firm pressure, then polish off the light grey veil after about two minutes. |
| Cure | Dry to the touch right after buffing. Fully cured in about 12 hours. |
| Price | $49.99 |
Best fornextzett Glass SealantYou want to do every window in twenty minutes and reapply in the spring.
| Rated for | Up to six months under normal driving conditions. |
| Bottle | 200 ml. Treats approximately 100 windshields. |
| Prep | Simple. The glass has to be clean and free of residue. |
| Apply | Rub it on with a paper towel or a microfiber applicator, let the film dry, then buff with a lightly damp microfiber. |
| Good to know | Silicone free. Washer fluid and glass cleaners do not affect it. Works on mirrors, house windows and shower doors. |
| Price | $30 |
Nanolex Ultra Glass Sealant comes in a 30 ml bottle, and only 3 to 6 ml is needed for an average windshield, so one bottle does the glass on several cars. The prep is demanding and the application leaves a grey veil you polish off. The durability is what makes the extra care worth it. It was developed, tested and made in Germany.
nextzett Glass Sealant is the simpler option. It is a 200 ml bottle, silicone free, and it forms a permanent SI matrix bond that nextzett rates for up to six months under normal driving. One bottle treats about 100 windshields, so you can do every window on the car, the mirrors, and the shower door at home without thinking about it.
How to apply a windshield sealant so it lasts
The steps are the same for either product. The prep is most of the job, and skipping it is why so many sealants fade early.
- Wash the glass. Clean the outside and inside of every window with a normal glass cleaner. Clean the wiper blades with the same cleaner on a towel, and clean the rubber seals around the windshield. Dirty or damaged wipers can mark fresh sealant the first time they move.
- Clay the glass. Windshields carry bonded contamination you cannot always see, and it gets between the sealant and the glass. Spray a clay lube on a section and work the Detailer's Domain Clay Sponge over it with light pressure. It is made for glass as well as paint. Do this above 55 degrees F, which is another reason to do the job in a warm garage.
- Polish and strip the glass. Old rain repellent, wax overspray from a car wash, and oils all sit on windshield glass. Nanolex's own directions start with Nanolex Glass Polish worked over the whole surface until it is absolutely clean. Then wipe down with Nanolex EX, which removes oils and polish residue before a sealant goes on and is safe on glass.
- Apply the sealant. For the Nanolex, shake the bottle well, put 10 to 15 drops on a cotton pad, and work it across the glass with firm pressure. You will see a light grey veil. After about two minutes at room temperature, polish the veil off with a clean microfiber. Leave the glass untouched and away from moisture, then give it a second buff with a lint free cloth to pick up the last of the residue. For the nextzett, rub it on evenly, let the film dry, and buff with a lightly damp microfiber.
- Let it cure. The Nanolex is dry to the touch right after buffing and fully cured in about 12 hours at normal temperature. Keep the car dry for the night if you can.
Finish the job: washer fluid and the rest of the car
A sealed windshield with summer washer fluid in the tank is a frozen nozzle waiting to happen. Before the first hard freeze, run the reservoir down and refill it with a winter fluid rated for the temperatures you actually see.
The rest of the car deserves the same thought before the salt arrives. I wrote about what winter does to a coated car in Driving a Coated Car Through a New Jersey Winter on the studio side. The glass is one part of that plan, and the part you will notice most, because you look through it every time you drive.
FAQ
How long does Nanolex Ultra Glass Sealant last?
Nanolex rates it for at least 18 months or 30,000 km. How it is prepped and how the car is washed both affect that.
Can I apply a glass sealant in cold weather?
You can apply it in a heated garage in any month. The product needs about two minutes at 20 degrees C for the solvents to flash before you buff, and about 12 hours to fully cure, so do the job indoors and keep the car dry overnight. The clay sponge also needs the surface above 55 degrees F.
Will a glass sealant make my wipers chatter?
Chatter usually comes from dirty or worn wiper blades. Clean the blades before you seal the glass, and replace them if the rubber is hardened. Buff the sealant residue off completely.
Does glass sealant help with frost and ice?
It does not stop frost from forming. Nanolex notes that de-icing is much easier on treated glass, and nextzett says its sealant helps make removal of ice and frost faster and easier.
Can I use glass sealant on the inside of the windshield?
Apply it to the outside only. Inside fogging is a different problem, and the fix there is a clean inside surface. Both products are fine on side windows and mirrors on the exterior.
Do I need to clay the windshield before sealing it?
On any car that has been on the road, yes. Glass picks up bonded contamination just like paint, and a sealant applied over it will not last as long.
Do the glass before the first storm
The smart move is to do it on a mild afternoon in November while the garage is still comfortable and the car is clean. Prep it properly, apply it patiently, and let it cure overnight. The first bad night drive of the season is when you will notice it.
Before the first storm Nanolex Ultra Glass Sealant, 30 ml $49.99 · rated for at least 18 months or 30,000 km · 3 to 6 ml does a windshield · drops blow off above 25 mph · ships from Norwood, NJ Or nextzett Glass Sealant, 200 ml, $30 Also in this post: Clay Sponge, $11.99 · Nanolex Glass Polish, $24.99 · Nanolex EX, $24.99 |
