Audio System Overhaul: Modern Sound in a Classic E38 - Detailer's Domain
What We Started With
The audio situation was bad. Not just old and tired, but actively broken.
Digging into the system revealed the rear deck speakers had completely disintegrated. The foam surrounds were gone, the cones were destroyed. Several other speakers throughout the car were blown. The head unit was the original BMW unit from 2001, which meant no Bluetooth, no aux input, no way to play music from a phone without some janky FM transmitter.
For a car that was otherwise being restored to a high standard, the audio needed serious attention.
Phase 1: AVIN and Focal
The first round of upgrades addressed the immediate problems and added modern connectivity.
AVIN Avant 4 Head Unit: This was the head unit choice because it looks OEM. The fitment is correct, the screen integrates properly, and you get Apple CarPlay. On paper, exactly what the car needed. More on this later.
Focal Flax Evo PS165ES: Installed in both front and rear door locations. These are serious speakers, proper component sets with separate tweeters and mid-bass drivers. A huge upgrade over the destroyed factory units.
Focal FDP 6.900 V2 Amplifier: A six channel amp to power the new speakers properly. The head unit's internal amplifier wasn't going to do these speakers justice.
BavAuto 5-inch Woofers: Direct replacements for the disintegrated rear deck speakers. They seemed like a good solution at the time.
This setup was a massive improvement over what we started with. Actual music instead of distorted garbage with Apple CarPlay for navigation and streaming. Felt like a real upgrade.
Problems with Phase 1
To be honest, the AVIN unit has issues.
In concept, the AVIN is great. It fits, it looks OEM, it has CarPlay. In practice, it has tons of glitches. The worst problem is ghost volume, where it randomly blasts the volume to maximum without any input. It can scare the hell out of you when it happens. The unit also freezes and needs reboots. It's frustrating because the form factor is perfect, but the functionality  has problems.
The BavAuto woofers also turned out to be the weak link in the speaker setup. They were direct replacements and easy to install, but they weren't matching the quality of the Focal components. The system sounded good but not great.
Finding something that looks as OEM as the AVIN but works better is going to be hard. That's the trade-off with these period-correct builds. Sometimes the options that look right don't perform right.
Phase 2: Helix DSP and Proper Engineering
After living with the Phase 1 system, it was clear that doing this right required starting over on some of the components. I brought the car to Jack at Allboros Customs for the proper treatment.
The components from Phase 1 were good, but the installation needed work and some pieces weren't fitting correctly in the doors. Jack removed everything and started fresh with new wiring and proper mounting.
Helix V TWELVE DSP MK2: This is the core of the new system. A proper digital signal processor that lets you tune the audio precisely for the car's interior acoustics. Time alignment, crossover points, EQ curves, are all adjustable. It transforms what the speakers can do.
The Conductor by Helix: A remote controller for the DSP that lets you adjust settings without diving into menus on a laptop. Clean integration.
The BavAuto 5-inch woofers were disconnected as they were the weak link in the system. With proper DSP processing and the Focal components running correctly, the sound is now incredible.
Subwoofer Placement
The sub ended up in the passenger footwell. I haven't seen that approach in a while, but it works for this application.
It keeps the trunk clear and puts the bass up front where it integrates better with the door speakers. Honestly, it sounds spectacular. The Helix DSP handles the integration and time alignment so everything hits your ears perfectly.
Current State and Future Plans
The system now plays lossless audio properly. Running files through the Helix DSP with quality amplification to the Focal speakers, it sounds like a completely different car from where we started.
I still have plans for further improvement. Looking at adding mids in the A-pillars to complete the soundstage. That would give proper imaging up front and really dial in the stereo separation.
The head unit remains the weak link. The AVIN looks right but the glitches are annoying. Finding a better solution that maintains the OEM appearance is the next challenge. I might have to compromise on looks to get reliable functionality.
Complete Audio Components
Head Unit:
AVIN Avant 4 with Apple CarPlay (issues noted)
Processing:
The Conductor by Helix remote
Amplification:
Focal FDP 6.900 V2 six channel amplifier
Speakers:
Focal Flax Evo PS165ES front and rear
Footwell subwoofer
Convenience:
Rendition cup holders with USB charging ports
Lessons Learned
This audio build taught me some important lessons about doing things right versus doing things twice.
Phase 1 was an improvement but not done properly. The installation had issues, some components weren't ideal, and the result was good but not great. Phase 2 required removing work that had already been done, which costs time and money.
Going to a proper audio shop like Allboros from the start would have been more efficient. Jack knew exactly what needed to happen: fresh wiring, correct component mounting, proper DSP integration. The expertise matters.
The AVIN head unit situation also shows the limits of OEM-plus philosophy. Sometimes the period-correct option just doesn't work well enough. I'm still figuring out how to solve that without compromising the interior aesthetic.
After the audio refresh, a respray is on the list. Probably 12 months out, need to recover financially from this project first. As long as the car has garage space, it can wait.
Previous article Exterior Restoration and Wheels: The E38 Visual Transformation
Next article Interior Resurrection: Restoring the E38 740i Cabin
