Valugard Neutralization System (aka: ABC Wash System)
Vehcile manufacturer studies have shown that failure to remove environmental contaminants from paint film can cause premature degradation of the paint system. While clay products are useful for overspray, they cannot deep clean the surface and pores of the paint. This can only be accomplished through a thorough chemical cleaning. The ValuGard Neutralization System is the most recognized and approved chemical neutralization system in the industry. In fact, major auto manufactures have issued technical service bulletins/advisories directing their dealers and port operations to use the ValuGard System for required repairs and pre-treatment for acid rain and industrial fallout repairs. Safe for both the user and the environment, the ValuGard Neutralization System is VOC compliant and uses no carcinogenic or toxic components. Economical to use. Step 1 or A Acid Neutralizer removes all waxes, sealant, silicones, road grime, lot stains and storage stains. Neutralizes acids deposited on the paint surface and in the pores of the paint during transportation and storage. Removes lot stains and wax build-up. Excellent pre-wash for body shops - removes silicones, waxes and other contaminates before sanding. Saves time when applied to used vehicles, removes oxidation, reduces buff time. Step 2 or B The second step of our Neutralization System, Alkaline Neutralizer deep-cleans painted surfaces to remove alkaline deposits. Also dissolves ferrous metal particles (rail dust) while breaking their bond to the paint so that they safely and easily float away. Step 3 or C The third step in our neutralization process, Detail Wash is a fine vehicle wash solution designed to return the paint to its original factory pH level. A true neutral carwash shampoo - not a soap - it will not strip waxes or sealants and is safe for use on all painted surfaces, trim and wheels. Excellent for everyday use, Detail Wash produces super long-lasting suds that remove dirt without stripping waxes, polishes or sealants. 128:1 super concentrate. VOC compliant. You can purchase the kit here: Valugard ABC Wash System
Previous article Ultimate Factories: Ferrari
Next article Let me know if you like the new banner?
