Project Car: 2018 Audi RS3 - APR 2.5 TFSI EVO Turbocharger Inlet Syste - Detailer's Domain
Project Car: 2018 Audi RS3 - APR 2.5 TFSI EVO Turbocharger Inlet System
Project Car: 2018 Audi RS3 seems to be one of the most mod friendly euros of late.  APR and other manufacturers have come up with some great go fast mods for this car and we are loving them.  In this update we installed the APR 2.5 TFSI EVO Turbocharger Inlet System.  Which will go great with the previously installed APR RS3 Front Mount Intercooler.  The APR Turbocharger Inlet System claims 14 WHP and 11WT alone.  That's impressive!  This unit runs for $749.00.  Our unit was of high quality and looked and felt impressive.  It took our mechanic about 3 hours.  This I would say is not an easy installation.  Make sure to have a dremel tool and the car on a lift.
Unfortunately the beautifully made Eventuri Carbon Fiber Intake had to be removed for this upgrade.
APR vs OEM - what a difference!
APR says:
The APR Turbocharger Inlet System outflows the factory components by up to 45%. This is achieved through elimination of the most critical restriction in the entire intake system, the turbocharger inlet pipe. Because of this restriction, no intake airbox / filter design can physically match the gains achieved by upgrading to the APR Turbo Inlet System alone. This is the first step one should take when upgrading their intake system and paves the way for even more gains.
The APR Turbocharger Inlet System uses a massive 4” carbon fiber inlet tube that attaches to the factory airbox, or upcoming APR Intake System. Attached to the carbon fiber tube is a massive 4” cast aluminum inlet which is organically shaped to retain the largest possible cross sectional area within the pipe all the way to the inlet of the turbocharger’s compressor cover. Despite the visually odd shape, keeping the cross-sectional area as large as possible is the key to the pipe's performance gains, and greatly outflows smooth looking continuously tapering designs.
Interlocking adapter rings form a port-matched ideal entrance to the turbocharger, while larger rings (sold separately) provide port-matched support for even larger hybrid turbocharger upgrades. A thick stainless steel heat shield protects the pipe from the hot turbocharger manifold, and an external stainless PCV pipe provides proper PCV placement without impacting the inlet’s design.
The Restriction
Turbo Inlet Pipe Turbo Inlet Pipe Turbo Inlet PipeTurbo Inlet Pipe Turbo Inlet Pipe Turbo Inlet Pipe
The factory cast inlet pipe is small. It has a maximum internal diameter of 2.8”, at the widest point, and is internally restricted as illustrated in the photos. This pipe is only capable of achieving a maximum of 490 CFM at 28” of H2O when tested alone. Attaching any intake system to this pipe will only result in a lower flow rate, and when using the factory back pipe, airbox, filter and inlet scoop, airflow drops below 430 CFM.
The APR Solution
Our cast inlet pipe is huge and on its own it achieves a staggering 710 CFM with the stock turbocharger adaptor! This is a 45% improvement over the factory part. When paired with APR’s upcoming intake system, airflow only drops to 690 CFM, a 60% improvement over the entire stock intake system! When attached to the factory airbox, filter and frontal scoop, airflow drops to 575 CFM, which is 34% better than the stock system and 17% better than the stock inlet by itself with an ideal entrance.  This further clarifies the point that no intake can outperform the APR turbo inlet if the factory turbo inlet is left intact.
APR’s engineers tested a multitude of other turbocharger inlet designs in pursuit of more flow and power. It was quickly determined the part could not act as an upgrade on its own because of the significant increase in diameter required. The rear inlet pipe also had to be upgraded to utilize this larger diameter. Other designs, which may look smoother, and offer a continuously reducing taper, are extremely limited. At 3.5”, 550 CFM is achievable. At 4” 560 is achievable. In contrast, our system achieves 710 CFM under the same test. Given how restrictive these other designs are, upgrading to our system, while still using the factory airbox, filter and frontal scoop, will outflow any intake system!
Dyno Testing
The APR Inlet System greatly outflows the factory inlet system, and for this reason, APR’s engineers have created a Stage 1+ ECU to take full advantage of the upgrade. While Stage 1+ is designed for use with an intercooler system, we tested the upgrade with the factory intercooler system to illustrate the gain from the inlet alone. In doing so, the APR Inlet system gained as much as 14 WHP and 11 WFT-LBS of Torque! When combined with the APR Intercooler system gains grew further to 37 WHP and 29 WFT-LBS. Gains will continue to grow as higher demands are put on the system via higher stages of performance.
Previous article Stunning BBS FI-R's on BMW M2 Competition
Next article Project Car: 2018 Audi RS3 - APR Front Mount Intercooler (FMIC)
